Ok I will track fastest lap of the season (both directions) and post at the track, nothing fancy probably just a laminated piece of paper.
Murray
CKRC Track Records - Feedback Wanted
Re: CKRC Track Records - Feedback Wanted
You should also add to the criteria ... you must complete the lap using only the asphalt ..... that would negate almost all if not all of Jakes times (plus a few others)
newson48
- First Name: Blake and Mark
- Last Name: Newson
Thank you to everyone for your feedback. The track records have now been posted in "Track Records" under "Competitor Info" - thanks to Dave for adding that in for us. I will get a hard copy posted on the timing board at the track soon as well.
Given that the track modifications will be completed in the near future, these records will most likely be set in stone now with no official races being run prior to the paving. That being said, now we can start a new list of records for the track post-modifications and set a new benchmark for everyone to work toward.
Shifter #48
