Vlr
Brian Turner
First Name: Brian
Last Name: Turner
City/Town: crossfield
Vlr
Post by Brian Turner »
Enyone out there have a salution to y I can't get the engine to run lots of fule fully charged battery and button pushed in jimmy and Fred rebuilt engine
evannadeau
First Name: Evan
Last Name: Nadeau
Re: Vlr
Post by evannadeau »
The red button has to be out to get spark.
Make sure the little wire coming out of the coil is connected to ground. If you follow how the manual says to wire up the coil, you will not have ground.
And or course, make sure the wire coming out of the magnito is connected to the coil.
Pull the plug out, and put it into the plug wire, then hold against the head and run the starter, checking if you have spark. CAUTION: try to only touch the rubber plug boot while holding it to the head to avoid being a shock.
If any of the wiring does not make sense, attach some pictures, and I'll try to help diagnose.
Brian Turner
First Name: Brian
Last Name: Turner
Re: Vlr
Thanks that helped found a loose wire now it's running almost ready for tomorrow test
evannadeau
First Name: Evan
Last Name: Nadeau
Re: Vlr
Fantastic. I'm out in the afternoon if you need any more help, but I'm pretty much a rookie. :)
I'm number 42. Jankie white electrical tape numbers for tomorrow. haha
Re: Vlr
Post by Fred »
Won't be anything to do with the rebuild .. that should be the fastest engine out there !
evannadeau
First Name: Evan
Last Name: Nadeau
Re: Vlr
Nope sorry Fred, I've got the fastest.
Re: Vlr
Post by Fred »
Evan I guess we will see !!!!
