Pedal extension freeline - wanted
BogdanP
First Name: Bogdan Popescu
Last Name: Popescu
Post by BogdanP »
Hi all,
I'm looking for some pedal extensions for a birelart cadet kart. does anyone has a used one for sale? or at least a recommendation / advice on what can I use as pedal extensions?
my son is around 4'2" and can't reach the pedals. a new set is quite expensive, so any advice is really appreciated.
thank you,
Bogdan Popescu
Re: Pedal extension freeline - wanted
Birel is hard as it has the Freeline pedals typically, if you try and mount standard extensions to the freeline pedal it will slip down and create issues (I have seen this more than enough times). Odds are you will have to switch the pedals to righetti and use the standard extensions, or with your son being 4'2" you will more likely need to build a pedal box. Overdrive sells a kit they make to universally mount the Righetti pedal box to any chassis. I would start by contacting Joey.
JChan
First Name: Joe
Last Name: Chan
Post by JChan »
Hi Bogdan,
Have you sort out the pedal extension? If not please send me a text as I have a pedal box (Noonan Foot box) you can have. It should work for your son’s Birel cadet kart.
Joe
403-540-9145
GobSmacked2021
First Name: Ken
Last Name: Venner
Post by GobSmacked2021 »
I’ve got some pedal extenders taken off my son’s Birel kart this spring. Text me. Ken @ 403-614-2185. Cheers.
BogdanP
Last Name: Popescu
Post by BogdanP »
Thanks everyone for the replies. I've managed to find some after market pedal extenders in the end.
