Laminated Track Maps with corner numbering
Ironring Racing
First Name: Josh
Last Name: Carter
Re: Laminated Track Maps with corner numbering
Post by Ironring Racing »
I'll order one. Thanks for setting this up!
Josh Carter
First Name: Blake and Mark
Last Name: Newson
Post by newson48 »
I will order some extras, but I want to get a ballpark count as to those who will actually buy one.
The gear ratio chart is an interesting idea. I will think about that. I just don't want any printing from the backside to show through on the main picture.
Perhaps someone wants to send me the charts for all classes? Lots on the go.....
2 ways to avoid bleed-through are to use heavy stock paper or just laminate 2 separately-printed sheets back to back.
Gear ratios are just that -ratios. Drive gear teeth divided by driven gear teeth. Ratios are independent of class, motor, and chain pitch (although many charts you will find imply they are for a specific pitch, which is nonsense)
If you google, you will find tons. Here's one example that claims to be for 35 pitch
http://www.gokarter.com/gearratio/35%20 ... 0Chart.pdf
I could crank one off in Excel for you in about 10 mins if you need.
First Name: Joey
Last Name: Guyon
Post by Joey Guyon »
I'll take two please
Chancery24
First Name: Ray
Last Name: Lord
Post by Chancery24 »
Based on my first outing on Saturday, I'm going to need all the help I can get! Pleased put me down for one. :D
Ray Lord
Rotax Masters
CRG Road Rebel #94
troubletitan
First Name: Michael
Last Name: Selvaraj
Post by troubletitan »
I found this online that seems to be Rotax Max specific gear ratio chart. Looks pretty user friendly, for input of the required data.
http://membre.megaquebec.net/mtlamla/ro ... alysis.htm
Karen165
First Name: Karen
Last Name: Humeniuk
Post by Karen165 »
Please put me down for two maps these.
Karen
Visotto123
First Name: Tony
Last Name: Visotto
Post by Visotto123 »
Ill take one as well.
Erin
First Name: erin
Last Name: peet
City/Town: calgary
Post by Erin »
We will take 2! THanks
franksartor
First Name: Franco
Last Name: Sartor
Post by franksartor »
Thanks Blake
I will take one
Frank
Franco Sartor
Locked
