Attention Racers! Night time cold weather is here – save your engines! Please make sure you either drain your coolant daily OR add a sufficient Antifreeze mix to your water system.
Your engines WILL be damaged if the temperature drops below 0.
If you have any questions please contact Overdrive Motorsports – [email protected]
Drain your radiators, FALL is coming!
