Mychron 3 Plus Accesories
Posted: Thu Jun 07, 2012 10:12 pm
by Jeff_Terns
Hello all,
Just curious to see what a few extras in the box are. I believe there is a speedo on the bottom right, and 2 of the same in the middle and top left.
what do i have?
Re: Mychron 3 Plus Accesories
Posted: Fri Jun 08, 2012 4:08 pm
Hi Jeff,
Here is the same photo marked with I.D.'s
- Mychron3.jpg (235.06 KiB) Viewed 12686 times
Posted: Fri Jun 08, 2012 4:13 pm
That speed sensor looks like it is for a 40mm axle. I don't use a collar for the magnet on mine. I just put the magnet on the axle and tape it with electrical tape (about 4 or 5 times around). Even though you can plug it in the bottom port on the back of the MyChron, it might not recognize it without the expansion box.
Posted: Fri Jun 08, 2012 11:22 pm
by Jeff_Terns
I'm pretty sure I have the expansion box. I was fiddling around trying to get the data to download, but I'm not sure about the software and drivers I need, or if that's important enough to fuss over.
Thanks John!
