What do you guys use for cooling the engine with the radiator?
Pawel2002
- First Name: Pawel
- Last Name: Pankiewicz
- City/Town: Calgary,Alberta
Do you guys use coolant or water? Since this is my first time doing go kart i just want to get some information about this.
Re: What do you guys use for cooling the engine with the radiator?
The guys that store their karts at the track use an anti-freeze coolant mix to avoid an accidental cylinder freeze. I store my karts at home in my garage and use just plain water. I start draining them between races in mid September and put a "no-water" sign on my steering wheel to remind myself.
Ckrc allows the use of antifreeze to prevent cylinder cracking when they freeze as John mentioned. If you plan to travel look at the said tracks regulations as many allow only water since antifreeze is hazardous if spilled on a track surface.
Pawel2002
- First Name: Pawel
Thank you guys for the info
jtunks
- Last Name: Tunks
I found out the hard way last year, DO NOT RUN JUST WATER!!! If it gets ANYWHERE near freezing, it can be bad... (One toasted Rotax engine later....)
- First Name: Keith
- Last Name: Olsen
I would say frozen, then toasted ;-Pjtunks wrote: Fri Aug 23, 2019 11:42 am I found out the hard way last year, DO NOT RUN JUST WATER!!! If it gets ANYWHERE near freezing, it can be bad... (One toasted Rotax engine later....)
