Setting the timing.
Posted: Wed Apr 07, 2021 7:18 pm
Well, the manual says the recommended timing is 3mm. From what info I can find, you set this by using a dial indicator, zeroing it at TDC, then turning the engine back until the dial indicator drops 3mm, and that is where the timing mark should be set to. However, even with the new style timing plate, I can only get about 2.5mm.
Is there a different way I should be setting the timing on this engine?
Thanks.
Thanks.
