A POINT OF CLARIFICATION FOR NORTH OF 49
All Briggs classes stay on their Mojo Tires (Suppliers are Overdrive Ms and K and K West)
Junior Rotax are on *Mojo D5* Or if you wish to go for the prize package LeVanto Tires (Mojo Suppliers as above ) LeVanto Tires # NO49 Sales # via MSR
Senior and Masters Rotax are on *Mojo D5* Or if you wish to go for the prize package LeVanto Tires (Mojo Suppliers as above ) LeVanto Tires # NO49 Sales # via MSR
Shifter tires Open Or if you wish to go for the prize package LeVanto Tires LeVanto Tires # NO49 Sales # via MSR
If you chose to go for the Prize packages you must order your LeVanto tires through MSR Before the cut off date of July 20 ... EVERY set you buy puts one entry into a draw to win another Brand new set.
MAX of 6 tires (Suggest a spare front and rear) To be declared and taken to Tech on Friday so they can be scanned (LeVanto tires will be pre scanned and issue to the driver Thursday evening or Friday morning)
Hope this clears up some confusion ..
Questions Call me !
NO49
Re: NO49
...but if you already have LeVanto Tires, you can use them and still quality for the ROK Prize.
Put another way, you need to run on LeVanto tires to be eligible for the ROK prize but you don't have to buy them from North of 49 event. But every set you buy from them gets you a raffle entry for a free set.
Correct ?
Correct ?
Re: NO49
Yes
Re: NO49
Further clarification on the tires from a question received this morning:
QUESTION:
Will you still be crowned N49 champion even if you don’t use lavento tires?
For example - driver wins their class in Briggs with mojos but second place wins the prize because they are on lavento tires?
ANSWER
Only the Rotax and Shifter classes will have the LeVanto tire option. All Briggs classes will be on Mojo only.
The LeVanto Tire option does not affect who will win a N49 championship. They are only a contingency sponsor. If the first place person is on Mojos, they are the N49 champion. If the 2nd place person is on LeVantos, they will still be 2nd but will be the first person eligible for the prize supplied by LeVanto Canada for that class.
Scenario 2: If the highest placing LeVanto tired driver finishes 5th, they will receive the prize supplied by LeVanto but the first place finishing driver on mojos will still be the N49 champion.
QUESTION:
ANSWER
